jpg to png
jpg to png
I wish to change some clip art images from .jpg  to .png for use in a website so that I can change backgrounds colours to transparent.
Help please?
Fixes: 126
Re: jpg to png
do save as in paint Wink
Will Moderate For Thanks
Fixes: 142
Re: jpg to png
Or for batch processing I recommend Irfanview.
Forum Moderator and Customer
Fixes: 13
Re: jpg to png
+1 for Irfanview... ( free )...
File > Edit > Batchconversion> drop down window shows "output version"  here you choose PNG .... then specify the output folder/destination
Re: jpg to png
Thanks gents.
I only have a couple of images to do so batch is probably unnecessary at this time.
Have saved the required images in Picture folder as .png (from Paint). Now just need to replace (copy/paste) the current .jpg images with the .pgn. Is there anything else to do once pasted or will they be "transparent" background?
The images don't look wrong background in the page builder until the page is published. The difference is slight (image background white, web page off-white, I do have the web page RGB and # format if required) but is noticeable.
kmilburn
Re: jpg to png
Saving the files as PNG's wont do anything beyond convert the format.
To get a transparent background you'll need to use an image editor which supports transparency properly (which paint does not).
If you use The GIMP,  the docs have details on how to Save Images with Transparency, there's also tutorial videos on Youtube e.g. https://www.youtube.com/watch?v=JRUARd3WML8
Edit: fixed link...
RadioFox
Re: jpg to png
Paint.net also allows you to convert background to transparent.
You just fill the background with "transparent paint".
http://www.getpaint.net/index.html
Re: jpg to png
@kmilburn, the tutorial link is apparently invalid.
RadioFox
Re: jpg to png
It works if you copy & paste into your browser, but here's the direct link:-
Re: jpg to png
Buy a copy of Photoshop?  Cheesy
Now Zen, but a +Net residue.
Fixes: 13
Re: jpg to png
What a waste of money, when you can download PhotoPosPro for free... does the same as photoshop... !
