iPhone 6 plus not suitable for pockets?
Apparently they're bending: http://www.independent.co.uk/life-style/gadgets-and-tech/iphone-6-plus-bending-irate-apple-fans-repo...
Call me 'w23'
Re: iPhone 6 plus not suitable for pockets?
This is going to become a major issue for Apple - they've sacrificed durability for a thin/aluminium casing.
Ha ha ha.
Fancy that.  Thin aluminium bending. Who would have thought.
That's a plus point for cheap flexible plastic.
TORPC
It seems even apple are cutting corners again, & what has happened to the quality control check(s) again ?Huh
One would think that checking the build for durability / against bending would of been paramount ?Huh
I still think apple have not learned from the iPhone4 days over the aerial incident
Goes to show that they are far more money orientated & not as much customer orientated as they should be
Typical too big for our boots syndrome, who can get away with selling cheap tat @ extortionate prices (where they know their sheeples will follow)
Steve
Seasoned Pro
To be honest though I have seen some other phones ' not suitable for pockets '  some about the same size as my tablet so far to big for my pocket!!
If life gives you lemons, make lemonade.
nanotm
wow, who'd a thought it yet another substandard phone released by crapple, I think I predicted this not so long ago.... Roll eyes
Fixes: 158
The number of young people I see with an expensive looking phone half in and half out of a back trouser pocket.
I presume they remove it before sitting down........unless some opportunist thief has removed it for them.
Customer and Forum Moderator. Windows 10 Firefox 63.0 (64-bit)
Fixes: 4
Apple products pfff, we have an aluminium Macbook here that is bent as well...... This wouldn't happen if jobs was still around. I just thought about that one  Lips are sealed
Fixes: 158
They should issue them to MPs as they would blend in well with the bent Parliament. Lips are sealed
DaveyH
Seasoned Pro
Fixes: 9
One more thing...
They've broken Touch ID and cellular connectivity on Some 6 and 6+ devices now too and had to pull the 8.0.1 update as a result
http://www.macrumors.com/2014/09/24/ios-8-0-1-issues-possible-fix/thttp://www.macrumors.com/2014/09/...
The explanation is pretty obvious. Apple will tell people "they have been carrying the phone the wrong way" obvious really. #antennagate
3Mb FTTC
Fixes: 232
...wrong type of pockets Cheesy
Forum Moderator and Customer
More on Apple having to pull the update:
Update pulled
TORPC
Quote from: Mav
Next the'll invent & patent the iTrousers  (iPants) as some refer them, with the pockets in the right places to avoid bending their cheap tat
Fixes: 62
Quote from: TORPC
Next the'll invent & patent the iTrousers  (iPants) as some refer them, with the pockets in the right places to avoid bending their cheap over priced tat
Slight correction
