envirofone
netreg
envirofone
Hi all,
has anyone used envirofone.com?  i got a couple of old SE phones laying around and could get £37 which basically pays for GTA IV when it comes out.  Cheesy
Fixes: 19
Re: envirofone
Just got a new nokia payg cheepo to replace the 3410 (same description!)  they had a bag in there for return of old mobile, and check on the website to see it is worth absolutely zilch....
checked it out on the environfone and it is worth 54pence.... so checked out a couple of other sites
Environfone    54p
mazuma        1.00
sellyourphoneright  has four categories    £2 to zilch depending on condition
sellyourmobile      working  £2
                        nonworking  £1
So could be worth checking out a few others before posting it off ! ! !
acr
Re: envirofone
I've used envirofone.com for two phones and got about £29 for them to spend in Argos. It takes a little time to receive, but they keep you informed via the web site of progress.
Tesco also do a recycling scheme with a minimum of 300 points (worth £3) for any working phone. Have a look at:-
http://www.tescomobilerecycle.com/index.php?option=com_content&task=view&id=1&Itemid=3
