dont rely on your SatNav tomorrow Wed 25th
pierre_pierre
http://www.bbc.co.uk/news/science-environment-16701407
Our planet is being bombarded by high-energy particles unleashed by the strongest solar storm since 2005, scientists say.
The charged particles are mostly a concern for satellites - which they can disrupt - and astronauts.
This CME is the largest recorded since 2005 and its high speed means we can expect it to reach Earth throughout Wednesday. Whilst sights such as the aurora are likely to be visible once again, possibly even further south than Sunday, there is growing concern that the CME could affect GPS and other communications satellites that orbit at high, Northern latitudes.
10 REPLIES 10
Fixes: 62
Re: dont rely on your SatNav tomorrow Wed 25th
As I am out walking with my GPS tomorrow I will report if it gets it's knickers in a twist
Fixes: 330
A temporary position of Plusnet Forum Moderator has arisen due to an unscheduled absence by one of our team.
The duration of the position is to be advised.  Wink
All the usual company benefits will apply. Cheesy
Customer and Forum Moderator. Windows 10 Firefox 70.0.1 (64-bit)
Life is tough enough without adding Linux into the mix.
Fixes: 28
If you are referring to OldJim`s postion..... he will let you know......when his satnav works !
Grin
Fixes: 62
I also have a 1:25,000 OS Map and a compass so you can forget all those happy thoughts about being short of one old grumpy moderator  Grin Grin
Fixes: 28
Ah yes.... the good old ways.... !.. Map reading...  Cheesy
Orienteering rules Ok!!
Mod last seen on the outskirts of Bruges
Now Zen, but a +Net residue.
Fixes: 62
Bad news - no problems whatsoever - typical alarmism  :crazy:
pierre_pierre
Worked OK in Essex as well
An end of millennium type of marketing opportunity lost. "You must buy the latest GPS unit to survive the solar flare."
