computere clock time
shutter
Fixes: 52
Been working on two laptops, that have had an update today... !
Yeah.. ok.. no problem....
But... just checked the little clock at bottom right !.. and it was an hour slow ! ..
checked my other laptop... and same thing.. so had to reset them both.
anyone else had this ?
7 REPLIES 7
TTman
Seasoned Champion
Re: computere clock time
@shutter
By Eck!!!! impressd.....takes me all my time to use one laptop!
Fixes: 80
@shutter Looks like you haven't got your date & time settings correct. These are mine, and the machine adjusts automatically:
Machine is a W7 Home Premium, btw.
shutter
Fixes: 52
@jab1  time setting was correct yesterday,... and this morning, before the update... that`s why I am mentioning it on chat... just wondered if anyone else had the same thing...
no big deal... !
Fixes: 80
OK @shutter . I didn't mean to infer that you didn't know how to set up your PC.Are your date/time settings as in my screen-grab, though? - if not, then something in the update (which one?) fouled them up.
shutter
Fixes: 52
@jab1   Yes... always have been for the past 20years or more ! ! ... Cheesy
Fixes: 80
In that case, I'm cofuddled - as my friend down your way would say.Cheesy
PeeGee
@shutter That should be taken care of by using a time server; though MS Windows screws up if you also run Linux - the former using "local" time, the latter using GMT/UTC for the hardware clock. that conflict always caused MS Windows to show GMT times if you do not edit the registry to use GMT/UTC.
Phil
Plusnet Fibre (Sep 2014), Essentials (Feb 2013); ADSL (Apr 2009); Customer since Jan 2004 (on 28kb dial-up)
