bargain?
bargain?
http://m.ebay.co.uk/itm/291171078947
Offering on hukd.  May invest , sends too good a price, but 8GB is small nowadays, so may be true.
Re: bargain?
Re: bargain?
Depending on your usage the speed of the device may be relevant  Class 10  vs Class 4.  The slower Class 4 is fine for many uses, but not everything.
Now Zen, but a +Net residue.
Re: bargain?
Usage I'm looking at is still photography, as opposed to video. Fire which,I assume, these will be fine.  Smiley
nanotm
Re: bargain?
depends on the intended use really, some devices you wont find any noticeable slowdown but newer ones designed to work at faster speeds you will, my old camera went from using a class 4 card and taking one shot every 20 seconds to 1 every half second with a class 10 card.....
