anyone had there browser freeze..?
kdoug007
last  2  days    has  been a nightmare..  i  even  phoned  PN..
  WHEN  I WENT INTO ANYTHING    EVEN  CHIT  CHAT  , IT  JUST  FROZE...
PN  as  normal  there  fantastic  team.    suggested i close  down  router..
  so i  did  that  AND  changed  my pc  memoary  by  2  digits..
  and  FINGERS  CROSSED.  seems ok,,
  any  others  had that  problemHuh??.
Re: anyone had there browser freeze..?
Yes IE8 on more than 1 PC, with windows XP, Initially I though it part of a patch release, will try a router reboot
Fixes: 12
Frequently on the suns website!
kdoug007
well since  i turned the  on/off    button  at the back of the PN  router,,, it  has  been  a  load  better,,,
Fixes: 348
Quote from: Sprite
and you admit to that in public?? Roll eyes Tongue
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
Javert
I had the same problem Friday & Saturday - what browser are you using kdoug007?  I'm on IE9.
peter10
Same problem here with IE9. Changed to Chrome and no problem.
Yes, been having intermittent freezes (and unaccountable slow downs) for a few days using FF (15.0.1) it usually corrects itself after 20-30 seconds or so. It is the only website in my entire bookmarks list to have this problem. Re-booting the router "seems" to help for a short while, but this may be just coincidence.
FF activity meter usually shows "waiting for Plusnet or community" or something very like it, so I have to say I rather suspect the problem is not my end.
Javert
Have had this problem (with IE) since Friday early evening - you have to wait for a page to open - then again to go to the next page - which can take up to a couple of minutes.  Then a message pops up - “Webpage not responding” that’s followed by a message asking “recover webpage?”  Clicking OK recovers the page and everything’s OK - until you want to go to next page!
Fixes: 12
Quote from: dvorak
Quote from: Sprite
Wink
They hav far too much flash on their site along with javascript.
snozboz
I've had a similar issue (though not as often as the OP), but I'm running Safari 6.0.1 on Mac OS X 10.7.5.  I think over the last few weeks it's gradually been happening more often - it was beginning to get to the point of me ringing Apple or taking my computer in to the Apple Genius Bar.  But if it's happening to others on different systems, maybe it's not an Apple-related thing...
For me, the problem isn't limited to specific websites.  When it happens, it's as if my mouse click or keyboard press in the browser has not been registered (to go to a new page, or go back for example) and the browser sits there with nothing happening (no spinning pointer-icon, progress bar or anything).  Then clicking reload (or anything else on the page or window) doesn't do anything.  Then finally it "wakes up" again, and sometimes gives an error or sometimes just goes back to what it should have been doing.
Sounds very hard to pin down!
Fixes: 20
snozboz sums it up quite nicely.... My Firefox does the same thing.... Nowt will move it... until you go to ctrl alt del, and then try to stop the process.... somehow this seems to wake it up, and it starts to do what you wanted the mouse to do...!...
Am running the latest "updated" new version of Firefox, but the previous one did it as well....
It is "intermittent" and not related to any particular websites or pages...
CX
Ever since Firefox got support for GPU hardware acceleration, I've experienced browser freezing. I always end up having to disable hardware acceleration in Firefox on Windows 7 systems containing nVidia graphics cards (irrespective of GPU generation and driver version). Interestingly, both Chrome and IE9 fine work with hardware acceleration on the same systems without instability.
Hardware acceleration should also be disabled in the Flash plugin, if disabling it in the browser settings doesn't help - I don't think the two are tied together.
I'm still running XP  with "automatic updates enabled", I booted up this morning and had IE8 freeze, had some work to do so switched off and noticed 1 update was being installed. Later this afternoon, have been working for a couple of hours, no freezing (yet).
I did notice the freezing started after a series of updates had been installed.
Wonder if it was a MS bug
Quote from: shutter
I find a simple "refresh" sometimes clears it, but not every time, just as often the refresh freezes
