any one know Bury St Edmunds roads?
pierre_pierre
I dont often use Parkway, but yesterday had to get to St Andrews street, my route is normally up to the next roundabout, back down the other way, turn down by Waitrose to it.
Dont remember seeing the signs below Yesterday, can we turn right now?
Fixes: 13
Re: any one know Bury St Edmunds roads?
Erm.... read the signs.... ! Cool
Metal sign with right turn crossed with red bar.... =  NO RIGHT TURN
(modified by the blue sign below, which indicates that cyclists buses and taxis MAY use the turn)
painted words on the tarmac    Buses & HGV ONLY ....
so unless you are in a bus or HGV you must NOT turn right there.... (Despite the car already doing it, on Google street view )...
If you haven`t seen the sign before, then you are guilty of "driving without due care and attention".... Ooops !   Roll eyes Cheesy
Fixes: 9
Quote from: shutter
... which has a white plate below and left of the number plate - looks like a taxi to me.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
pierre_pierre
Quote from: pierre_pierre
did you read what I wrote?  it had those signs three years ago when street view filmed it, and the road surface was also marked, it isnt now.
And yes that is a taxi
pierre_pierre
just put my glasses on and enlarged the Taxi up for Shutter
Fixes: 13
No problem with the taxi....  Roll eyes
If the signs are not there, and the tarmac is re-painted, or re-surfaced with no restrictions, then it should be treated as a "normal" right turn. ...
pierre_pierre
the trouble was - I was in the nearside lane, It had been No turn, so intended going straight on, I would like to know for when I go there again
