a Xmas present for Strat & Petlew
pierre_pierre
Fixes: 61
Re: a Xmas present for Strat & Petlew
Are you stringing me along Pierre.
I'd love to pickup one but if I can't I wont fret Wink
Customer and Forum Moderator.
pierre_pierre
Ahhhhh!! thank you pierre, just what I wanted. Perhaps you could all band together and pick-up a couple for Strat and I, which would without a shadow of doubt need no amplification of thanks from me.
Fixes: 74
*groan*
Plusnet Products Team
pierre_pierre
would you like a topical mug then Bob
or are you
