Your recommendation...
Anyone recommend a download CD to MP3 ripper preferably but not essentially free, that doesn't have tick-able (that you can't switch off) options to change the browser, software loader and various other settings on the PC?
Fixes: 16
Re: Your recommendation...
Have a look at "ATubeCatcher"... you can use it as a "stream catcher"   " screen record"    " video converter"  DVD/BlueRay/CD Creater" and "Audio Recorder"
And its free...
pwatson
CDEx is lightweight and free (open source)
http://cdexos.sourceforge.net/
