Wright's Traditional Soap with Coal Tar Fragrance
St3
Aspiring Champion
Fixes: 5
Anyone using this ? Or do you use somthing like it ? Ive been using it for a couple of weeks now because my skins been feeling ichy when its been warm and sunny.
Seams to make my skin feel better but it sure does make me smell of tar ....
https://www.amazon.co.uk/Wrights-Traditional-Soap-Coal-Fragrance/dp/B000SHKKJG/ref=pd_sim_121_3?_enc...
3 REPLIES 3
rongtw
Fixes: 12
Re: Wright's Traditional Soap with Coal Tar Fragrance
yes Ste they sell it my local £1 shop 99p  Smiley
Steve
Seasoned Pro
It's well known ( or it should be ) that just because something appears to be the same in them £ shops it is an inferior product compared with the more expensive one. Duracell batteries are an example.
If life gives you lemons, make lemonade.
twocvbloke
Amusingly (and annoyingly) I bought some LED lights from china (the battery-operated things, not bulbs, see link below) for £1.99 a piece, so bought three, found the same damned things in Poundstretcher for the same price, so bought one of those to play with 'til the other three arrive, will be interesting to see any difference in quality (or not) when, or if, they arrive...
http://www.ebay.co.uk/itm/302349388936
The Poundstretcher one seems to work nicely, nice and bright, switch is a but iffy, but, y'know, made in china...
