Working from home
TTman
Seasoned Champion
Working from home
 What do you think you would miss most if never going in to work and working from home? All meetings online,contacting fellow workers by e-mail, never going to the office!CoolHuh
16 REPLIES 16
Fixes: 73
Re: Working from home
Well, I'm retired so it doesn't really apply to me - but I would be totally unable to do my old job 'working from home'. How would I be able to get on the shop floor to examine material from eight miles away?
gleneagles
Fixes: 16
Being retired the question does not apply to me.....but if I was still working and was able to work from home what would I miss.....absolutely nothing....all I can see are advantages, no time lost in travelling, money saved from travelling, bit longer in bed....what’s not to like.
We are born into history and history is born into us.
gleneagles
Fixes: 16
Not sure what type of material you used to examine but I suspect a number of materials could be examined by computerised scanners to see if it met the required standards.
Fixes: 73
@gleneagles steel - and proper visual inspection was a necessity. Yes, someone could send a scan, but from experience (30 years of it), pictures don't always show the full picture.
PowerLee
I dont think my neighbours would appreciate my back garden being full of forklift trucks or all the lorry movements delivering faulty machines or collecting repaired ones.
I'd also have to modify the fence as the gate isnt wide enough.
gleneagles
Fixes: 16
I know nothing about steel but I recall that on the old steam trains they tested the wheels with a hammer and they could tell from the sound if there were any issues.....
PowerLee
Wheel tappers & shunters - you want a nice ringing sound from the wheel when you tap it with the hammer.
If its got a crack it wont ring.
I do the same with the load guards on the forklifts - tap the uprights on the load guard & a broken weld will be heard as no ring.
dave501
Fixes: 6
We would need to demolishing the garage to relocate our cobble and the neighbours would certainly have something to say if I started boiling crabs in the hot tub...
Fixes: 73
On the semi-finished material I'm talking about, you needed to visually examine it - depending on the quality/specification, superficial cracks in some grades weren't a problem, in others they were. And it had to be a full 360 degree, full length inspection - ever tried taking a 360 degree picture of 14" diameter bar that could be up to 10' long? - in sufficient detail, in a press shop where the lighting could be 70-80' overhead
Fixes: 185
I'm semi retired and have worked from home 2 days a week for over a year now!
I can tell you one thing I don't miss, that's the 50 minute drive to and from the office😁 and that was on a good day!
Strat
Fixes: 506
Yep, you need dye pen, ultrasound and radiography to be sure.
Customer and Forum Moderator. Windows 10 Firefox 88.0.1 (64-bit)
Fixes: 73
@Strat A little bit OTT for intermediate bloom material 😉 - although I agree if you're talking finished product.
Strat
Fixes: 506
@jab1
Ahh...I didn't know we were talking 'Bloom' stage.
Not quite at fabrication then 😂
Fixes: 73
@Strat No - my working life was spent in the forge departments at Firth Brown, Sheffield Forgemasters and SMP/Allvac, although I meandered into the finishing areas if things got quiet enough - not that it did very often.
