Windows 10 32 or 64 bit
Help required from someone who understands Windows 10
I have a Samsung laptop with an i3 processor and 6GB Ram which was purchased with Windows 8 64 bit
The windows 8 was upgraded to 8.1 and then Windows 10 I understand to use over 4GB Ram Windows 10 64 bit is needed so how do I tell which type was I upgraded to
In device specifications I have
System type 64 bit operating system,x64-based processor
Windows specifications
Edition    Windows 10 Home
Version     1803
When updates are done they come in as Windows 10 version for x64 based system
But in System Directory C:WINDOWS\system32
Very confusing
Brian A
4 REPLIES 4
Champnet
Champion
Fixes: 7
Re: Windows 10 32 or 64 bit
C:WINDOWS\system32 exists in Win 10 x64
@Anonymous, it's for backward compatibility with 32 bit version of Windows. A 64 bit OS will normally be able to run a 32 bit program but certainly not the other way around. So in order to do this a 64 bit Windows will keep copies of 32 bit libraries etc to facilitate this support.
Fixes: 185
That confirms it's a 64 bit version
 The windows system directory is always that , both for 32 or 64 versions., confusing isn't it. The problem is that so much of windows expects/assumes that the system directory is C:WINDOWS\system32 and so it was kept like that for 64 bit versions.
What's even more confusing is that, on 64 versions there is another directory called C:WINDOWS\sysWOW64 which contains any 32 bit system files.
Only Microsoft could come up with that...
Thank you all for confirming I have 64 bit
I learn something new everyday even at my age
Brian A
