Wifi on London underground.
SusanC
I recently transferred to PlusNet Mobile and have unfortunately discovered that PlusNet does not support Wifi on the underground.  I travel two or three times a week and I often deal with email on my iPad while travelling .  it looks like this service is not going to be available to me from now.  I will be very tempted to go a mainstream  supplier at an early opportunity.  The stand alone Virgin Wifi pass is rather expensive.
3 REPLIES 3
SpendLessTime
Aspiring Hero
Fixes: 82
Re: Wifi on London underground.
@SusanC
You could buy a 3 PAYG SIM as they offer free underground WiFi for all their customers. Then just swap SIMs when using the tube. Three PAYG credit never expires either so as you would use it slowly you wont need to worry too  much about the cost.
http://www.three.co.uk/Support/Free_WiFi_On_London_Underground
Mustrum
Fixes: 55
Or you could go to EE, they offer it too. But quite honestly, its not that great when I have been up there!
Minivanman
Aspiring Legend
Or you could just give yourself a break, sit back (if you can find a seat) and 'enjoy' the ride?
Don't limit the friends you haven't met with arguments you'll never have.
