Widening the forum..
mcgurka
I must admit, this is something I cant get my head around.
Finally got Vista loaded on my new system, after I overlooked the PSU and found it wasnt powerful enough, but one 1Kw PSU later, im here.
Can someone please tell me how the hell to get this outta the center of my screen, theres too much white!
Scott
Tamlyn
Re: Widening the forum..
Hi scott, are you using firefox or internet explorer?
If firefox, you can create a user stylesheet to force the forums to be full width.
It's not an ideal solution. We should have a better custom css solution by christmas but it's dependent on a bunch of other improvements that we are working on.
If you're using IE or opera there should be a way to do it too but I haven't tried it.
osb05
Quote from: mcgurka
Scott
Is there supposed to be a screen shot here? Not sure what you mean!
Fixes: 62
look at the post by Tamlyn for the instructions and mine for the amended code
