Why?
Why?
Does Dale Winton (National Lottery, in it to win it) seem to have forgotten to remove the coat-hanger from his jacket?
Fixes: 100
Re: Why?
Shhhh......that's been his closely guarded secret for years Shocked
Customer and Forum Moderator.
Re: Why?
It did occur to me, that its some kind of support for the brass-neck he has for the performance he puts in of a Saturday evening!!
Re: Why?
I can't bear to watch the man.  He makes me sick. I check my lottery numbers on line.
Fixes: 223
Re: Why?
agree with artmo, but i don't have any numbers to check.
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
