Which twerp pulled the plug out?
nozzer
Happened yesterday. Not very comforting.
5 REPLIES 5
twocvbloke
Re: Which twerp pulled the plug out?
Well there's your problem! You have a hole in your tank!! Crazy
beeceegee
Love the comment from the passenger "What could that be?"
rongtw
Fixes: 12
You cant see fuel tanker on ther side ,,, Scratching his head saying      "  why wont it fill up "    Cheesy
billnotben
I assume there has to be a breather/overflow valve of sorts?
Pete11
Seasoned Pro
Fixes: 4
They should've had a bloke under it with a bucket, at least they could have saved some in case bbq needed a bit of a boost. Roll_eyes
A float tip is pleasing in its appearance and even more pleasing in its disappearance.
Growing old is inevitable...But growing up is optional.
