Which laws or regulations would you get rid of?
Er! only serious answers please...
(some hope!!)
198kHz
Seasoned Pro
Fixes: 7
Re: Which laws or regulations would you get rid of?
The one about not feeding ducks.
Not young enough to know everything
Fixes: 9
The one which bans BMWs from using the inside lane on motorways.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
And Audis...
Also, whatever law that new car manufacturers have to follow which prohibits cars less than two years old from having functional indicators.
B.
Fixes: 13
One law I would like to see introduced......
Rear lights, and stop lights on buses, coaches, lorries, trailers, to be of effective/proportionate size .... and that the back of big lorries (anything bigger , and including, a Transit Luton type) should have a reflective strip at least 6 inches wide, all around the outer edge. (some do, but it is not compulsory).
It is ridiculous, to see a "Smart" car, with bigger  rear and stop lights than a 37 ton truck ....
The one that says, when I'm in a hurry, anyone in front of me must drive at least 10 mph below the speed limit.
Fixes: 13
the one that says "hulls...... stop following me "  Grin Grin Grin
The one that says all people over 50 must drive at 40 along the entire length of the A487, regardless of the speed limit being national, or 30.
F9 member since 4 Sep 1999
F9 ADSL customer since 27 Aug 2004
DLM manages your line the same way DRM manages your rights.
Look at all the pretty graphs! (now with uptime logging!)
On a slightly more serious note - all those laws that government ministers say should be ignored as they are petty.  If they're petty and unnecessary why pass them in the first place!!!!
I've tried to access the web site here
And it's useless!
Midnight_Caller
@hulls, Thanks for the link the site is very slow, but I have left some Comments on:
  • Photography
  • CRB check
How about all the politically correct nonsense we've had to live with for the past 10 years Wink
All of it, or just some bits of it?
Can't think of anything I'd keep Wink
Personally I think he should stick to cheap comedy (aka "motoring journalism") so his political comments are of negligible value.
BUT I think Jeremy Clarkson accidentally hit the nail on the head in todays Sunday Times:
"How many of these laws will actually get repealed - none."
What we need first is more common sense in applying the laws we have.  Cry
