Where to buy
- General Chat
- Where to buy
Where to buy
Where to buy
01-08-2016 8:17 PM
Hi, just after a bit of advice, I am thinking about buying an apple MacBook pro and my first thought was to buy from the apple store but there are cheaper ones available from online places eg. laptops direct. With it being an expensive purchase I am wary of buying online in case there are any problems with it and the money saved could end up being false economy. Just wondered what others would do.
Re: Where to buy
Re: Where to buy
01-08-2016 8:33 PM
You should get the same manufacturer's guarantee whether you bought online or in the Apple Store. If you buy online you also have the added protect of the Consumer Contracts Regulations plus further protection if you purchase using a credit card.
I always buy online for the CCR as it does give added protection plus, if you change your mind, you can return it (you may have to pay return carriage fees).
Forum Moderator and Customer
Re: Where to buy
Re: Where to buy
02-08-2016 8:27 AM
However, Apple laptops come with worldwide warranty, so if you chose to buy from somewhere else you'd still be able to take it an apple store for assistance within that 1 year period.
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
Re: Where to buy
Re: Where to buy
02-08-2016 1:33 PM
Thanks for the info guys. Debenhams plus are selling it for £1400, that's saving about £200 which is a lot of money. It's good to know that if anything went wrong I could still go to the Apple Store, I wasn't sure about that.
Re: Where to buy
Re: Where to buy
02-08-2016 1:40 PM
Re: Where to buy
Re: Where to buy
02-08-2016 1:58 PM
Hi dvorak, I think it's a buy it direct company which I think is laptops direct, I'm not keen on ordering from them, I've read that if you need to phone them it's 13p per minute and they also charge 1.5% for paying by paypal or cc. I think the John Lewis option is the best. I'm still undecided whether to spend that much money on a laptop, but that's another story!
Re: Where to buy
Re: Where to buy
02-08-2016 3:16 PM
Is there any particular reason why the Mac Air ?? a similar spec windows laptop would be cheaper
Re: Where to buy
Re: Where to buy
02-08-2016 3:24 PM
Friends who have macbooks have been raving about how great they are, I'm not keen on windows 10 and thought if I could afford it a mac would be a good investment. It's the MacBook pro 15 retina that I fancy.
Re: Where to buy
Re: Where to buy
02-08-2016 3:34 PM
I've got a macbook pro that's over 7 years old and the next round of OS upgrade is the first one it won't be supported for, I'm not sure you can say that about windows machines.
I don't think it would, I have both a high end windows machine and mbp (both i7, max ram, ssd etc.) and they were similar costs - but the screen on the mbp is far superior and the OS is so much slicker.
