Where does the charge go in rechargable batteries
Got a heavy photo weekend coming up, so I thought I'd recharge a couple of dozen rechargeable AA's of various powers. I finished this morning, as I use a fairly slow re-charger that takes 8 - 10 hours a set of 4, its taken a while.
Each set of 4 has been placed in a proper battery holder where there is no chance of them shorting out on each other. Out of curiosity I just popped the first set charged back into the charger, and they've been there for 4 hours now charging up!! Now I wonder why batteries that were fully charged 48 hours ago, not used, now apparently need charging again...
Fixes: 20
Re: Where does the charge go in rechargable batteries
Depends on your changer, the age of the batteries etc.
A smart charger will discharge before re-charging. a dumb one is just a constant current source.
Old batteries tend to loose their charge more quickly (Although 48 hrs is a bit quick!), and dependent on the charger they may not have been "fully" charged when they left the charger, even though they had been on charge for 8 hrs.
pierre_pierre
and it depends on what type they are  NiCd  (nickel-cadmium) has a shortish shelf charge state, supeceded by NiMH (nickel-metal hydride ) which is better, but the newer ones are lithium
try reading this http://electronics.howstuffworks.com/battery4.htm  and this for Lithiums http://www.greenbatteries.com/libafa.html
Fixes: 62
I use the Eneloop batteries which hold 75% of the charge almost indefinitely http://www.amazon.co.uk/s/ref=nb_sb_ss_i_0_3?url=search-alias%3Daps&field-keywords=eneloop&sprefix=e...
Quote from: Petlew
... I use a fairly slow re-charger that takes 8 - 10 hours a set of 4, its taken a while.
Such slow charging is not efficient, anything longer than a 2 hour charge time is likely to result in a battery not being fully charged, maybe +90% at best. But as others mention, the self discharge of NiCd/NiMH is pretty high, maybe losing 50% of charge in 14days is not untypical.
Also if some batteries have been left unused for sometime, it can take a few full charge and discharge cycles before they will hold close to full capacity again. This is likely to be what you have experienced.
3Mb FTTC
Thanks guy's, I've ordered a new charger, as it seems that is as much the problem.
Fixes: 15
Just found this......
http://www.amazon.co.uk/Duracell-Supreme-2450mAh-Rechargeable-Batteries/dp/B0031OE6LG/ref=sr_1_2/276...
which is a pretty good price for Duracell Re-chargables...(set of 4 = £4.09 )
pierre_pierre
you have to watch the postage on that sort of sale, its not Amazon, but 7dayshop
not Duracell, but got them even cheaper from Lidl £2.50 for four 2500 mah AA NiMH  local to me so no postage either
