Where can I get...
Fixes: 9
Where can I get...
these black plastic caps that blank off a cable gland like this:
Before anyone suggests the website printed across the image they are in china and I prefer UK sellers or ebay for foreign sellers.
I can get the glands from ebay but I can't find the plugs anywhere  Roll eyes I recently bought something with 3 pre-made holes in the case (it will live outside in many weathers). I will need to use one to pass a cable through and the other two will need semi-permanent blocking. Putting in glands that are plugged seems like the perfect solution for future upgrades.
Any ideas?
Fixes: 13
Re: Where can I get...
not exactly what you asked for....... but maybe this will do the job...
http://www.screwfix.com/p/tower-external-gland-kit-20s-ip66-pack-of-2/25996
Fixes: 13
Just realised they may well be just rubber shrouds to continue the cable thru.... so did a google, and came up with this...
http://www.cablecraft.co.uk/connect/cable-glands-accessories/nylon-blanking-plugs.html
to make it waterproof you could use silicon glue like "gasket seal"....or PTFE tape..
198kHz
Seasoned Pro
Fixes: 7
These the kind of thing?
http://www.mossplastics.com/cable-gland-blanking-plugs
Not young enough to know everything
Fixes: 13
Grrrrr.....how did you find them?  I been googling away for ages on this ! ! !  Cheesy
Fixes: 50
Nothing on RS so 4C's find is the best so far.
Customer and Forum Moderator.
No true cheapskates here then?  Shocked
The minimum cost solution would be to simply cut a short length (~20mm) of an old cable of suitable diameter and clamp it in the gland which is, after all, designed to provide a seal with a cable.
Yes, I fully admit that the proper 'stoppers' look a lot neater.  Wink
Call me 'w23'
198kHz
Seasoned Pro
Fixes: 7
Quote from: shutter
Search = cable gland blanking plugs
'Pages from the UK'  Second result (ignoring ads at the top of the list).  Wink
Fixes: 13
Huh!... I used Cable Gland Stopper for my search..... it`s not what you say.... its what you mean that counts  Grin Grin Grin
Fixes: 9
Quote from: 4C
Brilliant! Well done 4C, you've found what I spent hours on ebay looking for!
Quote from: shutter
Ah I was on an ebay sortie when I posted this.. google completely slipped my mind  Cheesy Thanks for trying though - I appreciate your help  Wink
Quote from: w23
I had thought of that, the only snag is that it's going to live outdoors in the damp and will need to protect expensive electronic equipment. Most wiring tends to be made of copper internally which corrodes so I can't take the chance of that rotting away and letting damp up through the internal sleeves. Otherwise it wasn't a bad idea but I would have gone with shutters suggestion with the plugs and sealant had 4C not found them.
Thanks everyone - people like you make the world a better place Smiley
198kHz
Seasoned Pro
Fixes: 7
A great result for the Chit Chat Forum.  Smiley
I do hope they're in stock.  Grin
Fixes: 9
Quote from: 4C
Shocked  Lips are sealed  Wink
Quote from: 4C
If not, you could always temporarily cut a piece of cable.....  Cheesy
Call me 'w23'
Fixes: 13
Durex work quite well in these situations as an emergency conception....  Shocked        Embarrassed    Grin
198kHz
Seasoned Pro
Fixes: 7
It's my understanding that they do cover glands quite well, at least in the short term.
Other brands are also available...
