Whatever next...?
Fixes: 196
Whatever next...?
iSmell: Japanese firm reveals the first 'smelliphone' add-on that lets you send scents to friends
In a video on DigInfoTV, ChatPerf demonstrates the Scentee device, which can be attached to smartphones and used to send smells to friends.
I can see a few people holding their phones under the duvet before pressing the Send button Grin
Any other daft ideas left out there?
Forum Moderator and Customer
Fixes: 100
Re: Whatever next...?
If the person you call says they are on the throne...hang up immediately.
Customer and Forum Moderator.
Unless it happens to be the Queen of course. Smiley
Fixes: 10
So how will that work then? Will you need to buy chemical bottles for it to use or something?
Fixes: 18
Put a sock in it... its all a bit of an armpit .......  Roll eyes
Smells a bit iffy to me!  Roll eyes
Geoff,
York.
ChatPerf (see I did read the link) must have a nose for a good idea.
Fixes: 18
"Whatever next" ? ? ? ? ..
OK...... I`ll start it off.......
How about a high end camera..... like a Canon DSLR or equiv.... being able to make phone calls.... and connect to the internet..... and have games ... and...... Roll eyes
It's heading that way with the Galaxy Camera.
It would look OK looking through a camera viewfinder and and at the same time talking to it. A lot better than trying to hold a tablet to your ear.
