What is the best way you have found to transfer contacts from
Fixes: 226
Re: What is the best way you have found to transfer contacts from
Never tried that way as I do find MyPhoneExplorer gives easy access to Contacts, Messages, Calandar, Call logs and files making for easy manipulation and editing.
But glad you got it sorted Smiley
Forum Moderator and Customer
TORPC
I would of tried it however,google plat said it was not compatible for the older phone Sad
Quote from: Mav
If they're both Android phones then you can use MyPhoneExplorer.
I've used that for years when it was only for old Sony phones.
I use it now on my Samsung android phone. Simple enough to use for contacts and a lot more.
I wouldn't trust any online service including google.
I'm sure google would never sell all your phone numbers to advertisers.
Infinity
Seasoned Pro
Quote from: TORPC
one sim to another sim on different networks
As pet tittle
Do you import contacts from sim to phone > export to new sim
or use the phones software suite ?Huh
Or have you found a better way ?Huh
What works best for myself is using an old Nokia 1112 basic phone.
Copy original SIM Contacts to Phone, put new SIM in, Copy contacts to SIM
It is extremely fast, a matter of seconds.
But I don't think it would  work with THREE Network SIMs
As a backup, I also copy Contacts to one of those free SIMs you can get, the phone does not need an active account to transfer Contacts.
Some of my more recent phones require an active SIM to do anything !
(Apart from calling Emergency Services that is)
TORPC
Cheers Guys
Much appreciated as always Smiley
That's the Tablet sorted not only for data as previously discussed , but also got all contacts in-case phone dies or bad signal whilst out & about Smiley
Fixes: 226
My tablet is not GSM enabled but I still copied all contacts to it as it is handy when out if I need someone's details.
Anyway, don't like the idea of placing an 8" tablet to my earlugs Tongue
TORPC
You saying that
Do you remember the (what appears huge) these days
Lugging a Ghetto Blaster on your shoulders, back in the day Tongue
Edit:
For the younger generation, this is what it looked like
nanotm
do you remember when they were forced to change the name to portable stereo system because the "PC brigade" got upset at the reference that they were designed for denizens of poor neighbourhoods often called "ghetto's" and that such a term was impolite to the inhabitants ......
TORPC
No I don't tbh
Fixes: 226
They weren't exactly built for portability. Then again, the tablets and phones of today can't dish out the bass like the old ghetto blasters could Wink
nanotm
well it led to people referring to them as "wog Box" which was infinitely more derisory, and a large part of the reason they became less popular..... of course it was also around the time that those horrible tinny headphone connected personal cassette / cd players became cheap and popular ....
TORPC
The time we're talking about was well before CD's Tongue
Quote from: PlusComUK
Using the SIM method is fine if you only want to transfer basic name and number info.
If you want to transer name, number, and all the extra info you have attached to them then you use MyPhoneExplorer.
Fixes: 226
It also makes editing contacts much easier including the addition of pictures as well as adding new alarms and ringtones.
