What is the best way you have found to transfer contacts from
TORPC
one sim to another sim on different networks
As pet tittle
Do you import contacts from sim to phone > export to new sim
or use the phones software suite ?Huh
Or have you found a better way ?Huh
Fixes: 250
Re: What is the best way you have found to transfer contacts from
If they're both Android phones then you can use MyPhoneExplorer.
Worked well for me to copy all my contacts and diary entries from my phone to tablet.
Forum Moderator and Customer
TORPC
Yes they are both Android Smiley
I'll wait others input before making a decision
Steve
Seasoned Pro
Sync all your contacts with Google its what I do.
If life gives you lemons, make lemonade.
myredhotcar
I am pretty sure Android does this automatically as long as you sign in on both devices using the same account http://www.google.co.uk/contacts
Edit: M Steve beat me to it
TORPC
Google sync is not an option as it does not work
Fixes: 384
it works fine.. if all your contacts are in google then it will sync between phones. worked every time i've moved phone.
My Broadband Ping - PN-Fibre
TORPC
Its not syncing the contacts or calendar,
That said it is syncing the Google Mail
So something not right
Fixes: 384
what version of android?
TORPC
2.1 Update 1
Fixes: 384
you used to have to switch sync on for each google component. might be worth checking in the settings.
TORPC
I have done that & the Icon changes to the synced icon & the date & time changed from 2012 to today, but not showing in the dashboard
Fixes: 384
should be here https://mail.google.com/mail/u/0/#contacts
TORPC
nope still not there Sad
TORPC
I managed to complete the task via BlueTooth
Steps I took
1. paired both phones
2. Tap contacts / phone book
3. Tap the options button > Send all contacts . BlueTooth
4. Accept vcard on new sim / phone
Job done
Google is pants anyhow Sad
