What is the best Step counter App for Android
TORPC
With the abundance of apps, with mixed reviews
I was wondering if you use a Step counter App for your phone & how efficient / accurate it is
It is also mentioned that the recommended Steps are 10000 = to 4.73 Miles (is this the same as you have heard) ?? see http://www.wikihow.com/Walk-10,000-Steps-a-Day
I have found a Step to mile converter online http://www.convertunits.com/from/steps/to/miles & is wondering how accurate it is ?Huh
Fixes: 176
Re: What is the best Step counter App for Android
I have a little cheap pedometer which clips to my belt.
Once calibrated it's quite accurate in comparison to a Viewranger app I had on my phone.
Customer and Forum Moderator. Windows 10 Firefox 64.0 (64-bit)
NorthEasterner
If you have a Samsung you can use S Health, which is very good.  Also has food tracker which tells you how many calories you've taken and how many to get rid off.
I can't comment for other Android phones
Ex Plusnet Fibre customer. BT Infinity Customer using a BT Smart Hub. If you wish to say thanks, please click the thumbs up Thumbs Up
Fixes: 349
I've got an LG G watch, which is excellent for counting steps. Uses android wear.
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
I'm with Strat, I use a clip-on pedometer Smiley
Fixes: 176
I used to do a 2 mile circuit once or twice a day...(slipped a little lately)
I can't remember how many paces were involved but the stride length varied with the terrain. Sad
