What are the technical terms for
A screen that when you rotate them the image on the screen rotates (like on an ipad)?
The term for 'pinch and expand' with a touch screen to zoom in and zoom out?
6 REPLIES 6
pierre_pierre
Re: What are the technical terms for
My camera does that as well as my Nokia phone
pierre_pierre
seems to be called Screen Auto Rotate
Thanks pierre, somehow got the impression the word "gravity" was in the phrase.
I'm writing a technical document for a piece of software, as the software includes a 'button' to overide the "screen auto rotate" I was after the correct phrase.
Stuck for words this morning Embarrassed
Hi Journeys,
were you also looking for the answer to the second one you mentioned?  You nearly answered it yourself as I'm sure it's simply called 'pinch to zoom'.
Call me 'w23'
@walker23, thanks so obvious now you've explained it Roll eyes
Quote from: journeys
Yes that's it.  On my Samsung galaxy it's called pinch to zoom.
