Welders.. whats the difference?
- General Chat
- Welders.. whats the difference?
19-04-2014 9:10 PM
I know tons of you are clued up on all sorts of technical and engineering stuff so i thought you'd be best to ask!
Whats the difference between all these different welders? - I've done arc welding (scary that lol) and oxy acetaline but I know there are others such as mig, tig, gasless mig (leccy - like arc - whats with that lol) etc.
So anyone care to tell me the difference? - Reason I ask is that I'm thinking of getting into welding for some car repairs and would like to make a reasonably well informed choice as to what to consider buying (that and I've been watching a lot of chop shop today on quest lol). My neighbour uses the gasless mig (which in my mind is an arc welder) but I've really got no clue as to where to start other than getting a good mask to protect my eyes lol.
Pesky cars and their rust.. why can't they all be made out of stainless like the DeLorean?
Re: Welders.. whats the difference?
19-04-2014 9:21 PM
You could get some practice & handy advice before spending out money on your own equipment.
For car repairs MIG would be the favourite as its easier to master & pretty cheap to buy the equipment.
19-04-2014 9:31 PM
You have to have a licence to use / store oxy / acetylene, then there is / was the deposit for the bottle(s), then the bags / torch / correct nozzle(s)
As PowerLee suggests (MIG) is the best way as it is the easiest to pick up
Dont forget to get yourself some gauntlets as well as the mask
Tip
Pop rivet a piece of leather on the mask to prevent sparks going down your neck
19-04-2014 9:58 PM
Quote from: PowerLee Have you checked out the local college courses for welding or car body repair?
There isn't one (or rather there was but it closed down and the nearest is now miles away).
Quote from: PowerLee For car repairs MIG would be the favourite as its easier to master & pretty cheap to buy the equipment.
But you've not answered the question! What is the difference between them?
19-04-2014 10:03 PM
19-04-2014 10:07 PM
MIG uses an inert gas which is fed through the same tube as the wire. The wire is fed at a predetermined speed depending on the current and weld depth etc. Different gasses and wires are used depending on what you are welding.
TIG welding is a bit like ARC welding only the electrode is made of tungsten and you then feed a filler rod in while maintaining the arc. Often used for aluminium.
Oxy acetylene is more like brazing - heat up the materials to melting point then they combine (a bit like soldering with a flame)
MIG without gas (i.e coated wire) is a bit messy and needs a lot of cleaning afterwards. It does have the advantage that it can be used in windier conditions than a normal MIG welder.
Best compromise for car bodywork is gasless MIG if you don't have much welding to do. Gas based MIG if you have lots of welding to do.
19-04-2014 10:14 PM
19-04-2014 10:59 PM
MAGS (MIG) is a relatively easy process for the untrained. It is also easy to lay down a run which looks ok as it's stuck but has little fusion.
TAGS (TIG) is good for thin plate work. It's actually more like oxy-acetylene welding with the use of a filler rod but the heat source is an arc as opposed to a flame.
All the vehicle welding I have done has been with oxy-acetylene as it's far more controllable on steel sheet of varying thickness as found on used cars with a possibility of rust areas.
Gasless MIG uses a flux cored wire with the flux gassing off and providing the shielding from atmosphere that the gas would normally.
Customer and Forum Moderator.
20-04-2014 12:57 PM
Get yourself an auto-darkening mask if you are a novice - a decent one which will switch instantly rather than thinking about it for milliseconds.
It makes it much easier when learning/starting to orientate yourself, the welding rod and the work piece if you can see what you are doing prior to lighting up the arc.
Oxy-acet is different and uses different lighter grade goggles.
Welding is a whole subject by itself. From my days in engineering we had people there whose whole job was simply science and the specification of welding techniques and materials to comply with the specs/job requirements. Then there was the business of weld certification and inspection......
It was one of those subjects that you didn't realise how little you knew and how complex it was until you talked to the experts who really did know a lot about every aspect.
20-04-2014 2:00 PM
also welders are supposed to undergo regular health check-ups for metal poisoning...
20-04-2014 2:22 PM
Goes without saying you should wear thick clothes and if working on a car make sure you have a fire extinguisher available as there are a number of inflammable things on a car.
Make sure you disconnect the car battery otherwise damage will occur to the electrics.
You may also need to get some mole grips (various shapes available) to hold stuff in place or / and magnets.
MIG is your best way to go but as suggested you will need to practice a lot on old metal before you get the hang of it.
Again as suggested by others get one of those automatic adjusting welding masks, if you use a non adjusting one it will be almost impossible to see the exact spot where you want to start welding.
I am sure the information about the Gas cylinders is correct but this may only relate to the very large cylinders, using small canisters works out very expensive so visit your local welding supplies shop as I am sure there are small gas cylinders that these regulations do not apply to, but equally you are responsible for their safe storage.
21-04-2014 10:32 AM
chuck a handful of fine white sand as flux on sizzling yellow hot metal before whacking it wiv'n 'ammer.
21-04-2014 10:36 AM
(although I wouldn't recommend it for vehicles)
although I have to say I preferred dipping the mild steel into a pot of carbon dust before dunking it in a bucket of icy water , the bang was always fun
21-04-2014 12:24 PM
21-04-2014 1:51 PM
The company I worked at provided safety prescription glasses which are quite a bit pricier than standard prescription glasses.
They seemed more capable of deflecting sparks than ordinary glasses and were replaced every year.
