Welcome to Chemical Brother
pierre_pierre
is this your new office then
is that a roger
Where you getting turned off?
Re: Welcome to Chemical Brother
Say WhatHuh
pierre_pierre
well we have to have some respite from all the moans  Cheesy Cheesy
You'll be flushed with success then pierre...well somebody had to say it.
techguy
I think his name implies he is a fan of the chemical brothers pierre as am I but I do get the joke, well done.
Welcome indeed Chemical Brother.
