Weather and work
Fixes: 20
Weather and work
OK. you guys... if you work outdoors, and need a weather forecast to tell you when it will start to rain.... have a look at this
http://www.accuweather.com/en/gb/portsmouth/po1-2/minute-weather-forecast/710325
The page is open at Portsmouth, this morning... currently, 09:53 it is overcast but NOT raining.... it says it will start to rain at 11:08 and stop at 11:30....
Never used it before, so would be good if you could monitor it for your location and see how accurate it is, and report back on here....
Fixes: 62
Re: Weather and work
As I've mentioned before I use Accuweather. I have it set on both my mobile phones. I find it very accurate and it can be set for very local areas Smiley
Fixes: 20
Well, It was "fairly" accurate, in that the rain did start .... but about 10 mins earlier than predicted.... and stopped about the correct predicted time... so ..... not bad... for today !..
Will keep an eye in it, for futures.......
DaveyH
Seasoned Pro
Fixes: 9
I tend to look at the sky...
Fixes: 179
You can always tell it's cold outside....when you go outside and it's cold
Customer and Forum Moderator. Windows 10 Firefox 64.0 (64-bit)
Where I am it said it would rain in 110 minutes. Turned out a lovely bright dry day.
I wouldn't say it was any different to the BBC local weather site.
All these so called "forecasts" change/disappear/update by the minute anyway.
Some are bound to be right. Angry
Fixes: 238
I still go by 'Red sky at night, shepherd's delight. Red sky in morning, shepherd's warning'. Works some of the time Wink
That and looking out of the window Tongue
Forum Moderator and Customer
Quote from: Mav
Works for me.
That and the seaweed.
Fixes: 9
Frequently use this detailed one,
http://www.lakedistrictweatherline.co.uk/index
Could lead to problems if they got the forecast badly wrong.
I've found Accuweather to be about as accurate as a politician's declared finances, predicting blazing sun while it's piddling with rain, hurricanes on nice calm days, and snow in the height of summer... Shocked
I use WeatherUnderground, they use data from a mix of home weather stations, MET office data and airport weather stations, it's been far more accurate than a lot of other weather sites I've tried... Smiley
http://www.wunderground.com
They also have apps for smartphones too... Smiley
