Venus and Jupiter fly pass
pierre_pierre
The pairing of Jupiter and Venus in the sky is set to reach its closest point in the coming days.
Despite being vastly far from one another in space, the conjunction will make them appear just a few degrees apart in the sky - about the width of a pair of fingers held at arm's length.
The pair can be seen to the west-southwest, shortly after sunset.
Venus is the brighter of the two, and Jupiter will appear to move in a line past it for the rest of the month.
tomorrows picture below
Fixes: 131
Re: Venus and Jupiter fly pass
With the unmistakable Orion constellation on the left Cool
Customer and Forum Moderator.
@p_p
Pierre what software is your jpeg taken from? it looks interesting
Fixes: 131
I've used this http://www.stellarium.org/ and found it very good.
pierre_pierre
mine is Starry Night Enthusiast 4.5\starrynight.exe"
I was sorting out my old CD and it was on one of those, it had a proviso that when it fires up , ignore the screen below and just click OK
Steve
Seasoned Pro
What do you get when you combine a year’s worth of NASA lunar projects into continuous render? You get this awesome video that shows you every hour of every moon phase in all of 2012.
video here
If life gives you lemons, make lemonade.
Fixes: 131
I'm glad I don't live on the moon, I'd get sea sick with all that rocking Smiley Undecided Smiley
Quote from: Strat
Yes that is excellent. Somebody in this forum recommended it some time back. It may even of been you Strat.
Quite near me is what is known as the "Bovingdon stack" an aircraft holding/circling point for Heathrow and Luton airports (I expect nadger where he lives is probably familiar with as well...er! it is you who lives near Leighton Buzzard isn't it?) Anyway, I had the binoculars on Jupiter last evening and a brightly lit aircraft flew right across it...it didn't do any damage to aircraft or Jupiter though thankfully Shocked Shocked
@strat: thanks stellarium, impressive, so much easier than HomePlanet (current software)
I've been using John Walkers home planet http://www.fourmilab.ch/homeplanet/ ; for several years, it is looking a "bit tired"
pierre_pierre
just been out and had a look, nice clear sky, the closest is tomorrow, if its clear I might take another pic, and get the houses next door in shot
pierre_pierre
tonights try
ImageDescription -
Make - Canon
Model - Canon PowerShot SX40 HS
Orientation - Top left
XResolution - 180
YResolution - 180
ResolutionUnit - Inch
DateTime - 2012:03:14 20:03:10
YCbCrPositioning - Co-Sited
ExifOffset - 232
ExposureTime - 1 seconds
FNumber - 4.50
ISOSpeedRatings - 3200
ExifVersion - 0230
DateTimeOriginal - 2012:03:14 20:03:10
DateTimeDigitized - 2012:03:14 20:03:10
ComponentsConfiguration - YCbCr
CompressedBitsPerPixel - 3 (bits/pixel)
ShutterSpeedValue - 1/1 seconds
ApertureValue - F 4.51
ExposureBiasValue - 0.00
MaxApertureValue - F 4.51
MeteringMode - Multi-segment
Flash - Flash not fired, compulsory flash mode
FocalLength - 38.82 mm
UserComment -
FlashPixVersion - 0100
ColorSpace - sRGB
ExifImageWidth - 4000
ExifImageHeight - 3000
InteroperabilityOffset - 4800
FocalPlaneXResolution - 16393.44
FocalPlaneYResolution - 16393.44
FocalPlaneResolutionUnit - Inch
SensingMethod - One-chip color area sensor
FileSource - DSC - Digital still camera
CustomRendered - Normal process
ExposureMode - Auto
White Balance - Manual
DigitalZoomRatio - 1.00 x
SceneCaptureType - Standard
Focus mode - MF
Image size - Large
Easy shooting mode - Manual
Digital zoom - None
Contrast - Normal
Saturation - Normal
Sharpness - Normal
ISO Value - 3200
Metering mode - Evaluative
Focus type - Manual
AF point selected -
Exposure mode - Program
Focal length - 430 - 15050 mm (100 mm)
Flash activity - Not fired
Flash details -
Focus mode 2 - 8
Auto ISO - 100
Base ISO - 3200
White Balance - Custom
Sequence number - 0
Flash bias - 0 EV
Subject Distance - 0.00
Image Type - IMGTongueowerShot SX40 HS JPEG
Firmware Version - Firmware Version 1.00
Image Number - 1020054
Sharpness (EOS 1D) - 0
Directory index (EOS 450D) - 40704
File index (EOS 450D) - 261121
@p_p:- good photographs, been thick fog here all evening..nada
drj
Better than mine - but I did have to do a 15 second exposure to get this
Fixes: 131
Not bad for a 15 second exposure Smiley
Indeed it is, how did you manage to hold Venus so steady, 15 seconds is quite long enough for astronomical movement to leave a trail rather than the bright dot you have achieved (note the movement trail of Jupiter) were you using an equatorial mounting tripod? If its hand-held that's quite something!!
Most people would struggle to hold a camera steady for split seconds let alone 15, especially in the cold!!
