VAT Reduction
Re: VAT Reduction
@shutter
Strange you had not come across QED before  Sad
But then , I was a Grammar School  boy............
Re: VAT Reduction
Or as the inland revenue calculate it:
Multiply the gross amount by 0.851 will give you the value excluding 17.5% VAT then multiply by 1.15 will give you the new gross amount inclusive of 15% VAT.
£117.5x0.851=£100x 1.15= £115
Re: VAT Reduction
@artmo
yes, I knew of that way but I thought at the time that 0.851 wouldn't be as easy to remember as "Jumbo Jet" !  Smiley
Re: VAT Reduction
Is it because Inland revenue employees can't use the divide key?  Grin
The recipocal of 0.851 is 1.17508, so one can either divide by 1.175 or mulitply by 0.851
Re: VAT Reduction
Or get someone else to work it out for you Cheesy
Re: VAT Reduction
Yes, but make sure it's  "itsme"........he knows all about reciprocals, so he must be a mathematical genius!
Re: VAT Reduction
Quote from: Strat
Here's something to cheer you all up...
Speakers required Smiley
Very funny indeed Strat
*techguy falls under desk with laughter.
The kind of thing the internet was made for, that
Re: VAT Reduction
Multiply by .9787234  Shocked (115/117.5)
Re: VAT Reduction
115/117.5? Where did these values come from? Should be 1.15/1.175, the answer would be the same but you would lose marks on your exam paper.  Grin
Re: VAT Reduction
do it in one old price x 0.978723404255 = new price
what is happening to the fuel 5%vat?
Fixes: 30
Re: VAT Reduction
Good point pierre. AFAIK absolutely nothing  Cry
The older I get, the earlier it gets late.
ADSL2+   Billion 8800NL
Re: VAT Reduction
Didn't see any reference to it at all pierre.
Re: VAT Reduction
Quote from: itsme
Not if it was being marked by a mathematician. The units are irrelevant as long as they are consistent, it's a ratio.
Fixes: 1,130
Re: VAT Reduction
Nothing is happening on the VAT on fuel.
So this reduction doesn't help anyone in basics, such as food, heating your home or getting about.
Fantastic.
Re: VAT Reduction
Food does not carry VAT, unless it's takeaways and restaurants and these have to charge 17.5% which has been reduced to 15%. So may be cheaper to eat out if they pass on the reduction.
