Utility providers (again!)
Fixes: 21
I have been with First Utility for a couple of years now.
My last fixed rate expired last Sept, when I did a check they were still the cheapest.
One thing I have found with them is that I can switch tariffs every month if I want to, as long as the new one is for a longer time than the old one there is no charge for it. Does any other provider do that? I know it used to be you will be charged £xx if you leave this tariff before it expires, but I have now switched twice this year to a cheaper tariff that is now almost back to what I was paying last year.
Edit: OK Spooling mistake on the title, I missed the U and got the I  Cry
1 REPLY 1
Fixes: 62
Re: Itility providers (again!)
are you going to change the title  Grin
