User names
User names
Quite intrigued by the current crop of Treasure Island related user names and avatars. But decided to change mine to leave the way open to "Old Jim" to adopt my cast-off Jim Ladd.
Re: User names
I was wondering about that.
So can you change your forum user names back and forth then?
Fixes: 154
Re: User names
It would appear so
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
Re: User names
Yup - you can change your display name as often as you like.
Thats one of the drivers for moving to SMF/Community rather than the old boards where you could only use your username.
Today happens to be International Talk Like A Pirate day. Wink
