Useless information - part three
shutter
Fixes: 52
anopendoorisnotajar
amotorisedvehiclemaynotbeacar
348 REPLIES 348
VileReynard
Fixes: 20
Re: Useless information - part three
a newspaper is black and white and red read all over.
Fixes: 79
A Golden Delicious is not delicious if it's got maggots.
RobPN
Fixes: 6
A Golden Delicious is not delicious  Cheesy
Fixes: 79
Actually, you ain't wrong, @RobPN  - they are probably my least favourite apples.
@RobPN
That’s fine. After all, a Granny Smith isn’t a granny... Cheesy
Mook
Champion
Unless she is!
I must have accidentally forgotten to write ‘necessarily’... 🤔
Fixes: 79
A flash in the pan usually means you've turned the microwave on with metal utensils left inside.🤣
shutter
Fixes: 52
@jab1  You don`t have to be a bright spark, to do that !    ..just a dim wit !  more like ! ! ! !  Cheesy
Fixes: 79
@shutter YOU don't have to be a bright spark - the microwave will produce it for you.😉
VileReynard
Fixes: 20
But the walls of a microwave are made of metal - they don't don't cause a flash in the pan. 🙂
Fixes: 79
@VileReynard Different alloy - some metals are not conductive.😁
VileReynard
Fixes: 20
Wikipedia says:-
In 1945, the heating effect of a high-power microwave beam was accidentally discovered by Percy Spencer, an American self-taught engineer from Howland, Maine. Employed by Raytheon at the time, he noticed that microwaves from an active radar set he was working on started to melt a chocolate bar he had in his pocket. The first food deliberately cooked with Spencer's microwave was popcorn, and the second was an egg, which exploded in the face of one of the experimenters.[11][12] To verify his finding, Spencer created a high density electromagnetic field by feeding microwave power from a magnetron into a metal box from which it had no way to escape. When food was placed in the box with the microwave energy, the temperature of the food rose rapidly.
RobPN
Fixes: 6
I see ... so nothing to do with a Vindaloo the night before?  Cheesy
