Unsecured Wi-fi
Unsecured Wi-fi
Just highlighting the internet icon on the system tray brings up a list of immediately local wi-fi's (presumably home systems as there is no industry nearby) there are at this time seven in the list.
I'm quite surprised that four of them by hovering the mouse pointer over them are described as "security type unsecured" the other three including mine are WPA2-PSK.
Fixes: 226
Re: Unsecured Wi-fi
The only unsecured ones in my area belong to the caravan site 200 yards away.
No good to me as you still need to login to access it - how do they do that?
Forum Moderator and Customer
Re: Unsecured Wi-fi
Log on to an unsecured WiFi is usually controlled by the Router/WiFi unit. In simple cases each username/password is individually set by the system manager. More powerful schemes involve password databases.
Now Zen, but a +Net residue.
Re: Unsecured Wi-fi
Quote from: Mav
I've wondered the same thing. When I go to a local beach there's a caravan site there that shows as unsecured. It seems you get there front page as it were with caravan ads etc but if you try to access the internet through them then it asks for a password.
Re: Unsecured Wi-fi
My neighbour is with BT, his WiFi router broadcasts two signals, one WPA2-PSK, the other appears 'open'.
I've always thought the second signal converts his router into a BT 'hot spot'.
kmilburn
Re: Unsecured Wi-fi
Quote from: Mav
It's most likely being done with a Transparent Proxy.
Once you've logged in, the proxy will stop redirecting traffic to the login page, and allow things to work normally.
itsme
Re: Unsecured Wi-fi
Would not say that once logged in that things work normally. In most case hotspots are controlled be a captive portal http://en.wikipedia.org/wiki/Captive_portal Not sure which captive portal BT Fon use but Fon use http://www.coova.org/CoovaChilli
kmilburn
Re: Unsecured Wi-fi
The captive portal provides the authentication service,  but you still need the transparent proxy to make it work.
How normally things work after that depends on how the proxy is configured.
Fixes: 10
Re: Unsecured Wi-fi
My router also has unsecured guest access with a login too. Very handy feature except for two things:
1) No one comes here and ever needs to use it
2) I can't remember the login details to even let anyone use it  Crazy
Fixes: 226
Re: Unsecured Wi-fi
Can I assume that this isn't available on all routers (I have the TG585v7 & 8, 582n, Netgear DG834Gv5 and BT Homehub and I bet none of these will do it)?
Fixes: 10
Re: Unsecured Wi-fi
No it's not available on all routers. They'll usually make a point of mentioning it if they have it.
You could in theory set it up yourself using a wifi AP and then a http tunnel / proxy.. it would be a bit of work but you could probably do it using Indy sockets. I never tried it myself but I would imagine that you could create a windows service to run on a windows XP / 7 machine 24/7 (eg on a mini itx system).
You'd also need to possibly intercept the DNS requests..
Fixes: 226
Re: Unsecured Wi-fi
Ok - you lost me after
Cheesy
Fixes: 10
Re: Unsecured Wi-fi
There used to be a freeware linux distro for mesh networking that supported it and could be run on just about any old hardware you had laying around. Can't remember the name of it now though Sad
Re: Unsecured Wi-fi
The TG585 does have MAC address control via its security settings.
itsme
Re: Unsecured Wi-fi
Quote from: Sprite
http://www.dd-wrt.com/site/index very good firmware if you have a supported router
Quote from: AlaricAdair
The above router firmware has a facility of reporting all WiFi devices, clients and access points, with their MAC's so easy to spoof other devices.
