UTube
UTube
Being a very rare UTube viewer. Can I transfer a UTube article to DVD?
Midnight_Caller
Re: UTube
Try:
Clip Converter
http://www.clipconverter.cc - Download from YouTube
or
http://www.downvids.net - Download from YouTube and Facebook Videos
Download as mp4 file, what you can converte to DVD, with a mp4 to DVD converter.
Fixes: 223
Re: UTube
ofc if the copyright allows it Wink
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
Fixes: 10
Re: UTube
also keepvid.com (you have to run the java applet so click yes / run)
TORPC
Re: UTube
Youtube centre is all you will need
Edit:
Fixed broken link
