Tyres
Tyres
Being in the market for a new set of tyres, my local ATS Euro (cough, spit) Master outlet offers inflation with nitrogen at £1.25 per tyre.
All major airlines inflate their aircraft tyres with nitrogen.
Anyone here ever inflated their car tyres with nitrogen? If so were there any advantages or otherwise.
Re: Tyres
I'm not planning to land my car at 150mph onto a runway with the wheels not rotating, so don't see the point.
A "revenue opportunity" is all it is.  Cheesy
I've read comments about damp air in tyres causing corrosion, but with modern alloy wheels is that an issue?
Razorback
Re: Tyres
Air is nearly 80% Nitrogen anyway so seems an excessive charge for the remaining 20%.
Re: Tyres
Unless you're going to drive at 30,000 feet...
The main real difference is that Nitrogen should be virtually 100% dry (no water vapour to condense/freeze at very low temperatures such as encountered at high altitude).
Some claim that Nitrogen escapes more slowly than air (80% Nitrogen + 20% Oxygen for practical purposes) but they'd still need the pressure topping up occasionally and this will cost if you intend to keep the tyres full of Nitrogen only.
Call me 'w23'
Re: Tyres
According to the British Tyre Manufacturers’ Association it's basically pointless expense.
See: http://www.btmauk.com/data/files/Nitrogen-inflation-for-car-tyres.pdf
Razorback
Re: Tyres
Quote from: w23
According to Back to the Future 2 we should all be flying in cars by next year
Fixes: 10
Re: Tyres
Always use real air - thats my opinion.
Anyone who's seen transporter 3 will appreciate that! You get trapped under water in your car and you still have amn air supply  Wink
Fixes: 196
Re: Tyres
Also used in A View to a Kill Smiley
Forum Moderator and Customer
Re: Tyres
From the ATS Euromaster web site http://www.atseuromaster.co.uk/nitrogen-inflation
I didn't say I was going to use nitrogen, just interested if other members had any experience.
Re: Tyres
The idea is that pure nitrogen supposedly doesn't expand and contract as it heats or cools as with regular air, so that hot tyres are still at about the same pressure as they were when they were cold, but for that to be of any use you need to be a racing driver, a pilot, or some twit in a chavved up corsa who thinks a 1.2L engine with cheap addons is a million horsepower beast...  Grin
Re: Tyres
Quote from: twocvbloke
OMG someone has rewritten the rules of physics on the internet Crazy
Quote from: Razorback
Re: Tyres
I thought it was more to do with nitrogen molecules being larger and harder to escape from an inflated tyre?
Re: Tyres
Quote from: HPsauce
I never said it was right though, I believe it about as much as I believe a politician's promises to do good... Grin
Re: Tyres
Indeed, I saw the  Grin
Re: Tyres
I understand you should not blow up your car tyres by mouth because of the high moisture content of your breath. This would lead to varying pressure as the tyres heat up/cool down.
Now Zen, but a +Net residue.
