Tyres again!!
Tyres again!!
My 05 Toyota Avensis has tyres I don't know the history of (one of my pet dislikes about used cars) so the tyres are to be replaced.
The 17inch wheels are currently shod with a mixture of budget 215/45. now here comes the anomaly.... the user manual specifies 215/50 section.
I have checked with three local tyre outlets who have all checked their back-listings and show that 215/45 is the correct size of tyres.
Calling my local Toyota main dealer got a lot of uhmm's and ahrr's and very vague responses, leaving me with the distinct impression that they didn't know what make and size of tyres were fitted to their cars. One would have thought the manufacturer would!!.
One tyre outlet <ATS Euro> suggested the problem with user manuals is that they are generic. The same car has a model with 16inch wheels and that maybe where the answer lies.
I have though ordered 4 new Goodyear Eagles 215/45 from Kwik Fit...the cheapest price, and the only product I would normally use KF for, plus I could book an appointment for fitting that suited me.
Re: Tyres again!!
Oh I forgot to mention...
215/50 tyres of whatever make are considerably more expensive (even online) than 215/45. in some cases £50+ more per tyre.
Fixes: 66
Re: Tyres again!!
Don't most cars these days have a plate on the inside of the drivers door detailing tyre pressures for the various size of tyres capable of being fitted to the vehicle ? That should show what options there are for 17" wheels
Re: Tyres again!!
What size does it say if you enter your reg number here: http://www.blackcircles.com/ ?
Call me 'w23'
Re: Tyres again!!
Thanks for that W23.
It shows 215/45. Which is what "everybody" else except Toyota themselves says are the right tyres.
Puts my mind at rest somewhat. Perhaps it was a mis-translation from the original Japanese Undecided
Re: Tyres again!!
In any case there's about 3% difference in diameter between the two tyre sizes - I believe that up to 5% is usually OK (a guideline typically used by suppliers of after-market alloy wheels).
I'd say having decent tyres with a good tread and correct pressure is much more important than the small size difference even if the 215/50 is somehow correct.
Call me 'w23'
Re: Tyres again!!
Had a quick look online to see exactly what the numbers mean. Here's the result..
"Here's what each section of the code means, using the tyre size and specification 175/65 R14 T as an example: 175 Tyre width in mm. 65 Tyre sidewall profile – sidewall height expressed as a percentage of its width. R Radial (rather than a cross ply) 14 Diameter of the wheel rim, in inches."
So in reality not a great deal of difference and the pricingHuh  probably simply the volumes produced.
Re: Tyres again!!
In theory the diameter of your wheel can affect the speedometer reading.
Now Zen, but a +Net residue.
Re: Tyres again!!
Yes, if the outside diameter of the tyre's around 3% smaller you will be travelling around 2mph slower at an indicated 70mph  Cheesy
Call me 'w23'
Fixes: 21
Re: Tyres again!!
Quote from: MisterW
Interesting, to see Petlew has issues with Toyota on what tyres should be fitted... and with Misterw info ... I have a similar "problem"...
there is a paper list stuck inside the petrol cap cover, which gives the tyre sizes and pressures..... on my car it lists 185/15 but the car is actually fitted with 195/15  ... I rang the dealer to ask what pressures I should use, and he said .... "use the 185/15"   ...
according to the "blackcircles" linky... the correct tyres fitted are 195/15
According to my Satnav... when my speedo reads 40 mph, I am doing 38mph on the satnav speed indication.... likewise further up and further down the scale....
Re: Tyres again!!
@ shutter, perhaps get an indelible black marker and change the 185 on the sticker to 195 (problem solved?)  Grin
Call me 'w23'
Fixes: 21
Re: Tyres again!!
Better than that.... I wrote my own sticky lable ! ! !   Cheesy  ( mainly because the original was in Kp or something,.. and I couldn`t understand it... so I wrote mine in lbs !  Smiley)
Re: Tyres again!!
@shutter, reference your sat nav speed differences. Used in three different cars I don't think my sat nav has ever agreed with the speedo at any speed above walking pace.
I brought it up in this forum some years ago when I first started using a sat nav, asking  which was the most accurate sat nav or speedo, given that speedometers are not 100% accurate anyway, there is a +/- percentage standard but I can't remember what it is. Only daily calibrated Police speedometers can be relied on for accuracy <as a matter of interest, speeding tickets have been beaten when it can be shown that a traffic car's speedo hasn't been calibrated at the beginning of a shift>
Anyway I digress, the answer I got was that it all depends on the whether the sat nav is going up or down hill through bends and curves, only on a bubble flat long straight road can a sat nav speed reading be thought of as accurate, so its probably safer (if its important at the time) to rely on the cars speedometer.
Fixes: 21
Re: Tyres again!!
My "new" car was supposed to have the pressure on the petrol lid as well. But it is completely blank. After a bit of searching around I decided on 2.1 (or 32 in old money)
Just found out I have 2 slow punctures on them as well. Off to get that sorted tomorrow.
Fixes: 188
Re: Tyres again!!
When I used w23's link above I have a choice
FRONT TYRE SIZE                      REAR TYRE SIZE
Select this option 205/55R16 W 91 (Same as front tyre)
Select this option 205/50R17 W 93 (Same as front tyre)
Select this option 225/40R18 W 92 (Same as front tyre)
I'm glad the wheel size fitted is the cheapest option Smiley
Customer and Forum Moderator. Windows 10 Firefox 64.0 (64-bit)
