Trying to join a forum where they use a test to confirm you arent a computer
- General Chat
- Trying to join a forum where they use a test to co...
2 weeks ago
I've just bought a car and want to join their owners forum. To register, or even to contact them, you have to type in a set of letters that they put on the screen to confirm you are human. The letters are either bold or not, and are either light on a dark background or dark on a light background, so there are four different types in each set. I've tried all capitals, all lower case, bold as capitals with the others as lower case, and dark background as capitals and others as lower case. All failed to be accepted.
Have any of you Plusnetters cracked the code in this type of verification? There's never an Alan Turing when you need one
Re: Trying to join a forum where they use a test to confirm you arent a computer
2 weeks ago
@penneck The 'captcha' you need to copy is in the form it is to prevent AI from being able to copy it - so far as you as a human are concerned, you only need to enter the characters as they are - either in upper or lower case - e.g. if the sequence is ZsfAApq - then you just need to type exactly that, and not for instance zSfAaPQ.
HTH
2 weeks ago
should be an option to read it out to you though?
2 weeks ago
as @jab1 says....
AXCfjb7Rtu needs to be copied exactly.... AXCfjb7Rtu other wise it will reject it and present a new format ... often there can be overwrites that cannot be decyphered... which makes it necessary to "cycle thru" the options given until one actually works ! .
2 weeks ago
The latest is RVRWWW, but with nothing to compare them with for size, it could be RvRwww, or any combination thereof. I have tried all sorts of combinations of the above, but haven't this time taken into consideration whether the letter is on a dark or light background. Certainly trying as shown above didn't get me anywhere
Only the Rs in the above can sort of be confirmed as upper case, whereas V, W, C, O, S, U, Z and probably other letters too could be upper or lower case with no obvious way of telling which they are if they dont show them in both upper and lower case at the same time
2 weeks ago
Seems stupid to make them unreadable, but I find picture ones, that ask you to select all images with traffic lights, say, annoying. One image may be very well disguised.
2 weeks ago
@penneck can you tell us the website so we can all have a play......
2 weeks ago
The few times I've come across a word or letter one I've usually just typed it straight as is. Ignoring any differences in case.
2 weeks ago
Uppercase characters seem to be slightly larger, the lines are straighter and the circles are round. Lowercase seem to be more freehand.
2 weeks ago - last edited 2 weeks ago
Sorry, missed this post, @penneck , but with respect, unless the site uses a really obscure captcha generator, upper and lower case letters should be easily discernable. I've not seen an instance for months when they aren't when I've had to use them, and sadly they seem to be coming more commonplace.
2 weeks ago
I'd agree with that for some of them, but that seems to be getting less common nowadays.
To save having to find out if the site will accept either case, I usually now type according to what I see.
2 weeks ago
For Champnet's benefit, the forum is at http://www.mazda6forums.co.uk, and I click on 'Register'. It isn't the best designed site. Once you have clicked on 'Register', go to the bottom of the 'Registation Agreement' then click on the 'I accept.... I am at least 16 years old'. That takes you to the form you need to fill in. The 'human test' is down the page. Note that one of the questions it asks is "Where was your Mazda built?". Considering all the countries in the world that build Fords (for example), that may not be as easy to answer as it appears. Another question is "What is the name of the river that runs through Londaon" - their typo, not mine (for once).
Good luck if you can pass the test. Considering I have tried and failed several times to pass it, I would be interested to know if any of you succeed.
2 weeks ago
I have to confirm @jab1 ‘s comment : the site uses a really obscure captcha generator.....
I can't really see the problem @penneck
I didn't register but looked at the letters and got them all correct - sometimes it helps to use the screen magnifier (Windows).
But why I say there shouldn't be a problem is because, as dvorak stated in post #3, there's an option for the letters to be read out to you! Which is how I know I got the letters correct, and possibly lower or upper case might not matter in this instance because it didn't mention which case they were during reading them out.
Edit: after seeing further contributions to the thread I went back and tried various combinations of refreshing the page and requesting a new sequence of letters.
As @billnotben says, they're all uppercase, and surprise surprise, I got the same letters presented to me each time!!!
X A N P T W
EDIT 2 - however, I tried another browser and got a different sequence so that's put paid to that little perceived anomaly.
2 weeks ago
No I didn't join but after running through a dozen or so "request another image" they all looked the same case so I would simply type as is without messing with upper and lower case.
- General Chat
