Trouble Accessing a Website
Kalvera
Hello all!
Just a quick Question: Is any one else having trouble getting on http://www.coolminiornot.com/ ?
Any feedback would be greatly appreciated!
Thanks!
Fixes: 62
Re: Trouble Accessing a Website
DNS record seems to be adrift
Kalvera
Ah, is there anything that i can do?
geewizz
Is it your own website? If so, contact the hosts. If not, there's nothing you can do about it until they have sorted out the DNS.
Kalvera
No, it's not my own website. I'll just have to be patient and sit tight!
Thank you very much for the quick replies.
Works fine for me using opendns as the dns
Kalvera
Is it possible to change yor DNS then?
Thank you
