Trick Question - from Brain of Britian - Radio 4 Saturday
Which is the odd one out of the following States of the USA.
The Northern most State
The Southern most State
The Eastern most State
The Western most State
Fooled me until I thought about it. (I've changed the format of the question a little).
Re: Trick Question - from Brain of Britian - Radio 4 Saturday
If you include all the States the odd one out is the southern most one.
Fixes: 58
Simple  but effective.
Customer and Forum Moderator.
pierre_pierre
it could also be the most western one
Took a moment, but I think I got it  Wink (Al ask ya later if I'm right)
Yes, that's what I worked out Hulls.  Interesting Cool
sidewinder
And If you include Hawaii?Huh
I did include Hawaii so I stick with my original answer.
sidewinder
Wouldn't it be the western most as well?
Simon_M
On the program, it was agreed that Hawaii was eligible to be considered. As journeys says, he's changed the question a bit from the way it was asked. If I remember correctly, I think they just asked for the names of the four states.
Not that that makes it very much easier....    Roll eyes
pierre_pierre
Ill stick by my answer as it doesnt matter where it is its the odd one out
Lurker
[sp] Britain (not Britian as spelled in the thread topic)
/pedant
Uhmm! even a US spell checker should find that one. Ah well! maybe not so much these days' perhaps.
Lurker
Quote from: pierre_pierre
The most western is not the odd one out in this scenario P_P.
The Eastern is the only one to begin with a vowel...
