Tray Bien, non
Fixes: 251
Tray Bien, non
We've had a large (50cmx38cm outside edge similar in style to this) serving tray made of melamine which has done us proud for a few years. Unfortunately, after daily use since purchase the handless finally split and now it has split through the centre left to right.
The shop we bought it from now longer stocks them and finding something of similar size isn't easy. So far I have found this from IKEA but at 58xmx38cm may be a little too large.
I've found lots of so-called large trays in places like Amazon but they all seem to be around 40cmx30cm which is too small. No luck with Argos, Homebase, BHS.
Does any one know of somewhere that may stock such a size tray - can be either melamine plastic or wooden?
Forum Moderator and Customer
alanf
Re: Tray Bien, non
Dunelm's has some around 48cmx32cm.
http://www.dunelm-mill.com/info/melamine_trays
Fixes: 251
Re: Tray Bien, non
Thanks, some nice patterns there.
Although 48cm wide is fine we think that less than 37/38cm would not be deep enough Sad
Re: Tray Bien, non
Nice one here.  http://www.rorydobner.com/large-grey-cat-monocle-tray.html
Same manufacturer, but through Fortnum and Masons (Iassume same size too).. https://www.fortnumandmason.com/products/rory-dobner-large-tray and only £3.00 more expensive.
Or go downmarket (never thought I'd say that about John Lewis  Grin )  http://www.johnlewis.com/john-lewis-large-rectangle-tray/p707904?sku=232423377&kpid=232423377&s_kenid=3cd6f7e4-683d-43d5-8655-064fd7781a8f&s_kwcid=404x59026&tmad=c&tmcampid=73&kpid=232423377  and  save yourself a fiver.
Or a more versatile option....  http://www.amazon.co.uk/Foldable-Detachable-Searving-Tray-Black-Chromed/dp/B00W5NA8PC/ref=sr_1_5?s=k...
nanotm
Re: Tray Bien, non
try looking on camping websites and shops, many of htem stock this sort of thing and charge a lot less than highstreet shops, a few years ago I got something similar from one a few years ago,
also places like ASDA and The Range
http://www.therange.co.uk/green-serving-tray/lap-trays/the-range/fcp-product/53315
often they have different names on different sites, picnic tray/laptray/serving tray/drinks tray
because you specifically want the larger size
another option would be too look at places selling things for oap's/disabled people
http://www.completecareshop.co.uk/kitchen-aids/dinner-trays/isagi-anti-slip-dinner-tray-large
more expensive but perhaps better for you needs
hopefully you find what your looking for at a price you like Smiley
Re: Tray Bien, non
@Mav, I was in Sainsbury's this morning and they had a tray in thyere similar to the one you are looking for. Smiley
Fixes: 251
Re: Tray Bien, non
@nanotm the second link seem viable except for one thing...
...it's green and I have an aversion to green especially that shade. I know I have stated previously that I owned a green car but that was different - I saved around £7000 on that Wink
@artmo I'll suggest SWMBO checks in their tomorrow when she's out shopping.
