Topic removal
Topic removal
I noticed that my topic, Ok criticising, the new appearance of the portal home page has been removed.
I hope this doesn't mean, you only want comments if they're good one's.
On the other hand if its been moved...where to please?
Re: Topic removal
I merged it into the existing discussion here
Re: Topic removal
Ok thanks Barry.
Re: Topic removal
Petlew
I saw your post in that topic and typed a reply to you. I clicked post and got an error page
I looked around and couldn't find the topic either!
Must have been when Barry was moving it
My reply was not posted.
Re: Topic removal
As an aside, if you ever need to find posts that you've made and suspect we might have moved them, simply visit your profile, and use the 'show last posts of this person' link.
So long as the post still exists on a public board, you'll be able to see it using that link.
Any static links pointing to a thread won't work if its merged into a older thread, as the post takes on the thread id of the oldest thread when they are merged. SMF dynamically updates the 'live' links via your profile though so you can still locate merged posts.
