Toothbrush
Fixes: 86
Toothbrush
I have quite a few teeth and just the one toothbrush to clean all of them.
Should I buy a few more toothbrushes or rename my one and only brush to a teethbrush.
Just an observation.
Customer and Forum Moderator.
Fixes: 17
Re: Toothbrush
Perhaps you should rename it "Peggy"  !  Grin
Re: Toothbrush
How about this:
Toothbrush
Fixes: 192
Re: Toothbrush
Perhaps when you have finished with your teethbrush you could mount it with a commemorative plaque  Cheesy
Oh, dear, we'll all be brushing up on our puns over this one Wink
Forum Moderator and Customer
Re: Toothbrush
Need something to get me teeth into!  Roll eyes
Geoff,
York.
Re: Toothbrush
Make sure it doesn't bite you Wink
Re: Toothbrush
Hope all our comments are tongue in cheek Smiley
Re: Toothbrush
Eee by gum!! Strat, this should get the punner's bristling and pasting fit t'fiil this thread...
Re: Toothbrush
You could get a pasting for that Grin
Fixes: 192
Re: Toothbrush
I only popped in as I was filling some spare time Wink
Re: Toothbrush
Don't worry Mav it'll be an amalgam-ation of all the best dental puns, all flossed up to look their best.
Fixes: 192
Re: Toothbrush
I'll brace myself for more of the same, then Smiley
Re: Toothbrush
It'll be a gas....
Fixes: 17
Re: Toothbrush
I have a cheesy grin on my face, reading these  Grin
Re: Toothbrush
That should crown it Smiley
