Too much technology!
Re: Too much technology!
On the subject of technology, my broadband speeds seem to be low.  I think it may be the wiring.
I've taken a shot of my current set up below - do you think I would benefit from a faceplate?  My attenuation should be quite low becuase it's a fairly short line.
http://www.simplifythis.com/blog/uploaded_images/twocans-729327.jpg
As long as the string is wet you should be OK; broadband works (though slower) down 1 conductor.
I know - I've done it  Crazy
think I have solved the problem Craig, get one person to stand and the other person to suffer the low connection and it will probably be a nice tight connection  Cool
edit fixed two typos
Fixes: 458
If the tins formerly contained Madras Curry sauce you can be sure of a fast connection Wink
On the OP subject I do find it depressing how the rest of the world is able to contact me whenever and wherever regardless.
I have no excuse for not finishing that report as I have access to work any time.
Holidays don't hold quite the same appeal when you can't 'get away from it all'  Sad
Customer and Forum Moderator. Windows 10 Firefox 79.0 (64-bit)
