Toilet cistern.
gleneagles
Fixes: 16
Toilet cistern.
Flushing syphon in the toilet reached the point where it had almost given up, so after checking what was available these days decided on a simple flapper system, this consists of a button, short lever, chain and a rubber plug on a hinge that just lifts and then drops down when the cistern is empty, the rubber flapper may need replacing at some stage but that's a 2 minute job and they cost around £6.
Compare that to the old syphon system where the water pipe  had to be disconnected and the cistern removed from the wall and requiring a new sealing washer etc, which has to be done in the first place to get the old one out.
All the new systems, of which their are several can now be replaced without the need to remove the cistern, how come it has taken so long for someone to come up with this simple idea ?
We are born into history and history is born into us.
27 REPLIES 27
rongtw
Fixes: 12
Re: Toilet cistern.
Money !!  Plumbers dont want anything you can repair yourself Cool_smiley
7up
Fixes: 14
Re: Toilet cistern.
Oh the joys of the plusnet forum and its odd topics...
If I flush then will this one go away? Funny
gleneagles
Fixes: 16
Re: Toilet cistern.
@7up
Didn't think it would be long before someone pulled the plug on this topic
billnotben
Re: Toilet cistern.
I replaced mine a couple of years ago. I finally gave up on the rapid pumping that was needed to get it to flush. As you say you have to remove the whole flushing unit just to replace the flappy washer thingamajig. So I decided I just as well replace the unit with an easy to maintain one. In B&Q they were about a fiver dearer than the bog standard ones. But on ebay they were cheap, delivered at less than half B&Q's price.
It was adjustable height for an overflow that flowed back into the toilet and the top section is easily removed to change the flappy washer if necessary.
twocvbloke
Re: Toilet cistern.
It's been about for decades, in the US of A of course, their bogs are pretty much all flapper flush cisterns, or ball-valve (which basically is a ball sat over the hole with a chain hooked up to it), but over here we stuck with the syphon system because that's what we stuck with, and you know how stubborn us brits are... Grin
Of course, in an emergency, it's always handy to have a bucket on hand, not to go in of course, but to fill up with water and pour down the bowl... Grin
7up
Fixes: 14
Re: Toilet cistern.
I think some of you lot are taking the pee with this thread Cheesy
gleneagles
Fixes: 16
Re: Toilet cistern.
BOGOF
Note to mods: That stands for Buy One Get One Free.
billnotben
Re: Toilet cistern.
It's rapidly going round the bend.
7up
Fixes: 14
Re: Toilet cistern.
This thread turned into a bit of a dump Cheesy
twocvbloke
Re: Toilet cistern.
Pretty much a bog standard policy here...Grin
7up
Fixes: 14
Re: Toilet cistern.
One day there may be change to that in the pipeline
twocvbloke
Re: Toilet cistern.
That'd have to be a high level decision to flush out the unwanted movements... Crazy
7up
Fixes: 14
Re: Toilet cistern.
And we'd have no choice but to go with the flow
198kHz
Fixes: 31
Re: Toilet cistern.
I'm sewer this thread is going down the pan.
The older I get, the earlier it gets late.
ADSL2+   Billion 7800N
