Toilet Seats
Strat
Fixes: 506
Toilet Seats
Soft close toilet seats are a cunning invention by toilet seat manufacturers to boost sales of conventional seats as they are broken by visiting soft close seat owners.
They should either exchange all conventional seats for soft close versions or withdraw sales of soft close seats immediately.
Customer and Forum Moderator. Windows 10 Firefox 88.0.1 (64-bit)
22 REPLIES 22
Minivanman
Aspiring Legend
Re: Toilet Seats
Soft closers, soft paper, and soft wet wipes.
The world has gone soft!
Where is the Daily Mail when you need it Wink
Don't limit the friends you haven't met with arguments you'll never have.
shutter
Fixes: 47
Re: Toilet Seats
Erm..... let me google that for you   ! ! ! !  ......   http://www.dailymail.co.uk/home/index.html  Cheesy
twocvbloke
Re: Toilet Seats
This house had a soft-close bogseat, it stopped soft-closing of it's own accord, and then later the hinges rusted out and some sticky goo oozed out (presumably the resistant material used in the soft-close jobbie) when the seat detached itself, plus it was thin plastic that bent out of shape under my ample bottom causing the occasional aiming issues for the aft torpedo launcher, so I replaced it with an MDF seat with proper hinges and life on the throne is good... Grin
Alex
Fixes: 12
Re: Toilet Seats
I've got one and I only did because:
  1. My old seat broke.
  2. I got a standard seat from Argos for £20, which lasted for 3 weeks before breaking too. The screws had come out the wood so it was not very good (I will refrain from using one word here).
  3. Went to my local B&Q and this one has seemed to have lasted longer so far (i.e. better than nothing).
Re: Toilet Seats
Too much information!
Alex
Fixes: 12
Re: Toilet Seats
Cheesy
I like it, made me laugh. Best we get back on topic before the Police perform Knuppel
Re: Toilet Seats
@twocvbloke wrote:
... causing the occasional aiming issues for the aft torpedo launcher
I'm in tears here.
Strat
Fixes: 506
Re: Toilet Seats
It seems to be a subject close to many peoples' heart.
198kHz
Fixes: 31
Re: Toilet Seats
Eh? I've always thought that Strat's heart was in the right place - now I'm not so sure. Huh
The older I get, the earlier it gets late.
ADSL2+   Billion 7800N
Re: Toilet Seats
After rusted screws and fittings, from toilet humidity ! we(e) now only buy toilet Seats with all plastic fittings.
They last much longer, and look better !
shutter
Fixes: 47
Re: Toilet Seats
You shoud not abuse them..... I do hope you are not buying them in bulk,  as with the Marmite... You will probably cause a run on them.....
twocvbloke
Re: Toilet Seats
@Anonymous wrote:
I'm in tears here.
There were many words I could have used, but, the aft torpedo launcher gets the best results... Funny
Re: Toilet Seats
Tall Poppy syndrome (a perceived tendency to discredit or disparage those who have achieved notable wealth or prominence in public life.)
Harassment is when someone behaves in a way which offends you or makes you feel distressed or intimidated. This could be abusive comments or jokes, graffiti or insulting gestures.
Harassment is a form of discrimination under the Equality Act 2010.
Harassment is both a criminal offence and a civil action under the Protection from Harassment Act 1997. This means that someone can be prosecuted in the criminal courts if they harass you.
It also means you can take action against the person in the civil courts.
Jaggies
Re: Toilet Seats
Cut in to squares and hung on a nail in the privy.
