Toaster Query
Fixes: 135
Toaster Query
By what method does a Toaster determine when the bread is toasted to the required degree.
Mine often gets it wrong depending on the temperature outside.
I have it set at 50% of the dial and in winter the bread comes out a light brown whereas in Summer it is ejected a dark brown to almost black.
I would expect the dial not to need adjusting throughout the year once the desired toast colour is found by trial and error.
Customer and Forum Moderator.
VileReynard
Seasoned Pro
Fixes: 11
Re: Toaster Query
It's probably just a timer thing.
In summer, the ambient temperature is a bit hotter, so the elements achieve a higher temperature - maybe?
Re: Toaster Query
Use best steam coal on the fire, give it time to glow, and make sure the fork prongs are evenly inserted in the bread.
Now Zen, but a +Net residue.
Fixes: 9
Re: Toaster Query
If you are making toast for the family, say 8 slices it can be quicker to do it under the grill, which also gives you more control over it.
Fixes: 135
Re: Toaster Query
It's a family of one here.
Fixes: 19
Re: Toaster Query
1. the toaster uses a "clockwork" timer type thing...
2.. If it is a four slice toaster and you only want two slices... put one in each slot  if it is a two slice toaster, and you only want one slice... keep an eye/nose on the toaster and switch off early in the toast cycle, as it will do it much quicker with one slot not in use...
3.... the freshness of the bread... i.e. the water content, will also determine how "brown" or not, the toast is...
4 use the middle of the toasting slot for slices ...
Re: Toaster Query
It's magic, 'nuff said... Grin
Re: Toaster Query
What do you get if you put the Spice Girls in a toaster?  ---------------------------  Pop tarts!
How do you toast a chimpanzee? -------------------------------------  under a gorilla.
A blonde woman, with brown hair, walks into a shop and goes to the shopkeeper and asks "could i buy this toaster?".To which the shopkeeper replies, "sorry i don't sell to blondes". So the blonde goes home - determined to buy that toaster- and colours her hair red and goes back the next day. When she asks to buy the toaster again the shopkeeper says "sorry i don't sell to blondes". So she dies her hair black and goes back the next day. When, once again she asks for the toaster the shopkeeper who replies " sorry, I don't sell to blondes" . The blonde who at this point was furious, asks the shop keeper "how did you know I am blonde?" to which the shopkeeper replied "because that "toaster" is a microwave".
Sorry girls!
MJN
Re: Toaster Query
Many toasters employ a simple bimetallic strip which moves in response to heat and ends up unlatching the toaster (and disconnecting the heating elements) after a period of time. Normally you would see darker toast in winter given that the strip takes longer to respond to the heat. However, you seeing the opposite is perhaps down to the bread being drier due to the higher ambient temperatures.
198kHz
Aspiring Champion
Fixes: 11
Re: Toaster Query
It's expensive, but with this toaster you can see the bread while it's toasting.
Remember you are unique - just like everyone else
rongtw
Fixes: 12
Re: Toaster Query
if you want toast you need one of these Smiley
https://www.youtube.com/watch?v=LRq_SAuQDec
Re: Toaster Query
Nah, you need a Photonicinduction 10 Second toaster... Grin
https://www.youtube.com/watch?v=UUPSGvWr6xE
For one, it doesn't demand everyone eats 400 rounds of toast like Talkie... Grin
Fixes: 135
Re: Toaster Query
My bread is stored in the freezer otherwise it would go off as I don't eat a lot.
My current toaster has a 'Frozen Slice' setting.
