Time Machine
Time Machine
So I've built a working time machine which will transport items one day back in time. Can someone tell me the calculation necessary to make sure the item lands in the correct place?
Now Zen, but a +Net residue.
nanotm
Re: Time Machine
no but I bet theres an app for that  Wink
Re: Time Machine
Infinity
Seasoned Pro
Re: Time Machine
I've got THREE Time Machines !!
Fixes: 16
Re: Time Machine
Well, You would have......  Roll eyes
Fixes: 10
Re: Time Machine
Quote from: AlaricAdair
Sure thing:
-24:00:00
Re: Time Machine
No. I mean the calculation to work out the physical coordinates of my desk 24 hours ago. Such factors of the rotation of the earth about its axis and around the sun and the motion of the solar system within the galaxy  etc etc...
pwatson
Re: Time Machine
Surely if your time machine worked you just have to wait until you've found the answer and then you can come back to "now".  As you don't know the answer then we must unfortunately conclude that the machine doesn't work...  Sad
Fixes: 10
Re: Time Machine
I'm kinda with pwatson on this.
You know the time machine works and so ultimately you already know how to calculate the coordinates - otherwise you wouldn't know the machine works in the first place  Tongue
Re: Time Machine
Position is relative.
Re: Time Machine
Unless the time machine is operating outside the Earth's frame of reference, the time machine and items transported will be part of the Earth 'system' and only local co-ordinates will need to be calculated.
Same problem as "Does a Ford Transit carrying birds weigh less if all the birds take off", to which the answer is "No".
F9 member since 4 Sep 1999
F9 ADSL customer since 27 Aug 2004
DLM manages your line the same way DRM manages your rights.
Look at all the pretty graphs! (now with uptime logging!)
Thunderclap
Re: Time Machine
Cool You mean find the X Y Z Q ?
X Y and Z are obvious as they are a vector relative to your fixed datum - or frame of reference as avatastic says. Your datum could be the center of the sun, a phone box, or a hot tub. Easy, even Pythagoras could work it out... But Q?
From the Ladybird Book of Time Travel
As a time traveller you will know that gravity introduces all kinds of relativistic warps into the space time continum. Think of your datum as a start line drawn across a rubber road. As your car drives forward, the road bends around you and thus, you are not certain of your true distance from the start line, even though the tacho is incrementing normally.Q is a kind of fiddle factor with mass, velocity [gravity] and delta [time] added - vis the quality of the space time travel vector. A Q of 1 is optimal, but after an ato-second, Q becomes a very large number - time travellers are hence recommended to assign Q a value based on their best guess.
Relative to the fixed datum, the resultant space time travel vector is likely to resemble a wobbly spline than a straight line.
Re: Time Machine
Ignoring Q for the moment, just taking X,Y and Z is not an easy equation you need to take into account
• earths rotation speed at the equator - 2.688000e+6  ff
• Earth’s orbit speed around the Sun - 1.80096000e+8 ff
• The sun orbiting speed around the galaxy at - 1.32283465e+9 ff
nanotm
Re: Time Machine
perhaps something like this could help you https://itunes.apple.com/gb/app/redshift-astronomy/id390436752?mt=8
since its not the position on earth that matters so much as it is the position of earth relative to the rest of the universe at any given time ....
Fixes: 183
Re: Time Machine
you've got your flux capacitor configured incorrectly
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
