Tilt test.
Tilt test.
I thought you technical oriented guys may be interested in this picture I came across. All buses have to be tested, so they can tilt to a minimum of 28°.
This its an old photo of early tilt testing.
Health and safety...what's that? Cheesy
Fixes: 12
Re: Tilt test.
i like the analogue angle tester lol
Re: Tilt test.
What puzzles me is, if you look closely there are two testers. One shows 28 degrees and other shows 38 degrees. Odd!!
Fixes: 62
Re: Tilt test.
Nor really
One is the platform and the other is the bus.
The difference being due to the suspension on the bus
Re: Tilt test.
Platform's at 28 degrees, bus is leaning at about 35 degrees, simples... Cool
VileReynard
All Star
Fixes: 11
Re: Tilt test.
The one attached to the bus is at a different angle, due to the suspension.
Fixes: 12
Re: Tilt test.
I thought we had a similar topic to this previously.. Strat started one moons ago when he was young  Cheesy
https://community.plus.net/forum/index.php?topic=126093.0
and here's one google images turned up on a chinese site.. seems they're good at destroying busses / coaches along with ports:
Fixes: 4
Re: Tilt test.
Grin
Re: Tilt test.
Quote from: 11110_110
looks like 28 and 45 to me ?
Due to it's low-resolution and excessive JPEG compression, the picture ain't 100% clear, so looks like the scale is 0-10-20-50-40-50-60, etc., so unless the method of counting from 0 to 100 has changed at somepoint, then logically speaking, that "50" looking number between 20 and 40 would actually be 30... Grin
